Old 10-06-2015, 02:44 PM   #70 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
I'm finally going to be properly able to test this soon. First of all, I have to correct a plumbing issue I have. The original place I spliced the tank heater into turns out to send the hot coolant into the transaxle rad, so instead of heating that I was mostly heating the air. There was an increase in the transaxle temp as read by the scanner, so it was working, but not very efficiently. I will now set that up properly so most of the 750 watts will get where it's supposed to go.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
The Following User Says Thank You to orange4boy For This Useful Post:
Daox (10-07-2015)
