Old 10-10-2015, 10:42 AM   #22 (permalink)
kafer65
Tinkerer
kafer65's Avatar
Silver - '15 Mazda CX-5 Sport
Team Mazda
90 day: 37.23 mpg (US)
Thanks Cd.
And again: Mo betta or less better than the blacked out version? I'm using the Rustoleum Peel Paint version of vinyl coating.
The gap isn't as tight as the picture shows on the fronts since it was taken from high above. They rubbed a little on the front edges and, embarrassingly, when I gave my in-laws a ride. I had 1/4 inch gap but once the vehicle was loaded down that gap disappeared and the gap fillers got pulled off into the wheel wells I cut another inch off to open them up and so far its been golden.
Since the brackets are clamped onto the wheel well lip just by the tension in the stainless alone no real damage was done. I reoriented the brackets that twisted on the Lexan and tighten the gaps on a few of them an all is well.
Mirror deletes, 80% grill blocks, wheel covers, 50 psi tires = 6% better MPG avg. over a year. Wheel skirts overcoming ethanol winter fuel mpg losses and more!
http://ecomodder.com/forum/showthrea...ead-30641.html
The Following User Says Thank You to kafer65 For This Useful Post:
Joggernot (10-11-2015)
