Old 10-13-2015, 10:03 AM   #2 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by Cd View Post
My '93 Civic fires right up every single time - sometimes the instant i turn the key.
Most of the time i don't even hear the starter.
However, the car has always had a very weak spark in several ( if not all ) cylinders .
Power seems weak, but this is an old car with a lot of miles. The car I'd also an automatic.
the distributor is new, the wires and plugs as well.
Will i see a big FE Improvement by fixing the issue ?
What is the condition of the ground wire on the cylinder head. You can a simple test by taking some jumper cables and making four extra temporary grounds then recheck spark.
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
Cd (10-13-2015)
