The side window update wasn't too hard to do once there was a decision about "what" should be the end result.
The expanding foam was trimmed up to match the window frame and Gorilla tape lines the edges.
The overall window was shaved down about 1/4 along upward slope and then along entire top. This allowed room between the side-glass and the window frame once a proper-type rubber seal to be installed. Six plastic screws with plastic wingnuts now secure the side windows. Even with a fair amount of water pressure from a garden hose, the windows don't leak. Loosening the wingnuts makes removing the entire window in about 25 seconds. The window easily fits in the storage tray behind the seats - vent galore!
As luck would have it - the smaller rear side windows looked out of place since they lacked this exposed rubber seal....
To be continued...
~CrazyJerry
