Originally Posted by ksa8907
What is the gap set to? You mentioned that you have good grounds but what about a good supply voltage?
Gap is set to factory specs. Supply voltage ....hmmm...well I need to test that.
The distributor ( which has a coil built in ) / plugs and wires are all new.
I'll recheck the grounds again this weekend. I just looked it up, and there are a lot more than I thought :
