Thread
2000 Insight - TLC and ecomodding build
10-14-2015, 03:48 PM
289
permalink
Ecky
ND Miata
- '15 Mazda MX-5 Special Package
90 day:
40.51
mpg (US)
I'm also experimenting with several rust prevention methods, for the bits that can rust. Looks like I'm going to do a sanding + dip in phosphoric acid, and then paint with Rustoleum high temperature enamel for parts that will get warm (e.g. catalytic converter heat shield, maybe the cat itself, brake calipers, misc. bolts) or primer + another low temperature Rustoleum paint for other things, such as the bracket that holds the battery in place, brake and fuel lines, etc. On my battery holder bracket the plastic/rubber coating had cracked and the metal underneath was showing the first signs of oxidation:
Ecomodding 2015 MX-5 Miata
Honda Insight w/Acura TSX engine
2000 Insight TLC & Build Thread
pgfpro
(10-14-2015)
Ecky
View Public Profile
Send a private message to Ecky
Find More Posts by Ecky
