I'd just like to add,if you go with the mirage and you have the option,have them hook it up on an alignment machine in front of you and look at the rear axle measurement to see how bad it is out of specs BEFORE you get the deal gone through.
If it is badly out of specs (excessive toe in) you will be going through tires like underwear.
Rear is not adjustable (no shimming no adjustment possible)and a pain in the neck to deal with the issue. (there are solutions but not simple)
If nothing else,you can use it to get a deal on the car if it is not within specs.
Other than this one issue I love mine to death. and if you are used to getting MPGs in the twenties,you will be giggling like a schoolgirl when you see the numbers on the display!
