Originally Posted by pgfpro
I will finish my full grill block this month. I'm not going to do a belly pan now because I want to rally the crap out of this thing in the snow, and I'm worried the belly pan won't last to long.  So my plan is to put a bunch of miles on her this winter running 80% waste solvent. Then I will pull the fuel system apart and see how everything looks. If it looks good the Insight will be converted to waste solvent also.
So I'm going to put all my energy into the Insight now and try to go for
100 mpg.  I will be posting all the modifications on the Insight thread.
I understand not having a belly pan for that reason! It would not last anytime with such abuse! Be sure to coat your inner fenders and belly with WD-40 or a equivalent to inhibit rust on your beautiful car. You probably know this, but just in case
Let us know how that fuel system looks, because I may look into using WS as well
You will be able to get to 100 mpg by next year, no doubt
If I ever get the turbo/ultra lean/engine mod stuff done, I'd love to give you a run for that prize...
