Old 10-21-2015, 05:55 PM   #67 (permalink)
RedDevil
90 day: 56.29 mpg (US)
In fact all 6 burned out!
I blame the bad connection in the makeshift plug. The wires just wouldn't solder onto the tabs, they gripped it by shape - but not enough.
So it had not been making contact for a while. I depleted the battery in EV mode, drawing its voltage way below the buddy pack - enough to make it bridge the bad connection and suddenly deliver the full voltage differential to the lamps.
I redid the tabs with a 120 Watt heavy duty soldering iron (the same I needed for the 6 mm diameter wires in the pack - a 30 Watt iron is helpless with those) and now the tabs are soldered through.
Also I swapped the lights round so the reflectors face the full open side:
It is starting to look like something that belongs on the front grill
Yet I'd rather not have that high voltage cable run the length of my car for a vanity show
