Old 10-22-2015, 08:20 AM   #1220 (permalink)
ecoboy
RE: Several other have proved it can be done
It was I who question the possibility of 84 mpg EPA rated. First aerodynamics hardly come into play in an EPA test, the speeds only average 48 mph in the "high speed" highway test. Even a first gen Insight only gets 59 highway in the EPA test with a manual, the automatic CVT only 49. A 1900 pound hybrid with aerodynamic attention and a 1 liter lean burn engine. If the Elio could even match it I would be impressed but 84 mpg is about impossible in an EPA test for any car.
Several others like that centurion prove high mpg can be achieve by combining a light weight vehicle with aerodynamics. It is not even a question. If your moving less air and your vehicle only weighs 1250 lbs you will get the mpg.
If you can live without FWD and do a RWD reverse trike fully areo you could get the same mpg for much less money.
Safety is the big buzz word, and I get it. I am not sure I would feel safe driving a smart car that as it is about 1/2 the length of a normal car.
