Old 10-22-2015, 07:44 PM   #2225 (permalink)
e*clipse
Permanent Apprentice
Quick question when wiring multiple small switches, like the TO-247:
If all the switches in question are connected to a common high or low side and a common output, can you just gang all the gate pins and use a common resistance?
Or would it be better to run an individual resistor to each one?
Is the ability to run them in parallel connected to the gate resistance?
Thank a bunch,
E*clipse
