Lawn edge air dam
I would Not do the air dam. it will add frontal area to the car. your under tray is designed to allow air to pass efficiently enough. Wish could find the post that said this. Air dams are good if there is a lot of under car openings. You might want an air dam at the front and rear tires like the early Insights.
