It was the easiest windshield removal I've ever done! Basically none of the urethane adhered to the glass and only marginally better to the window mounting flange.
Using a couple of pieces of memory foam does a nice job of evenly distributing the pressure across the windshield while it's being prepped for installation.
Halfway through the process this interesting bug stopped by to inspect the job.
With a "brand name" (MMM) of urethane applied to the mounting flange the windshield was ready to be set back into its home. A new rubber trim seal was also fitted as a little extra protection against leaks.
Another easy job completed and the job site Manager approves the work!
~CrazyJerry
