Old 10-26-2015, 10:28 AM   #8 (permalink)
wildman10
wildman10's Avatar
Following on . . . . . . .
The same paper gives optimum ratios of cooling mass air flow to charge mass air flow (M1/M2) of 5.7, 4.4 and 3.8 for pressure drops of 250, 500 and 750 Pa respectively for an intercooler efficiency of 80%. For a maximum charge air mass air flow of 850 CFM (64 lb/min, 0.48 kg/sec) these figures give cooling air mass flows of 2.7, 2.1 and 1.8 kg/sec respectively. For the core area of my intercooler, 500mm x 260 mm, without ducting, these cooling air mass flows imply air speeds at the intercooler face of 38, 30 and 25 mph respectively. Similar calculations show speeds of:
• 80% efficiency, duct area ratio 1: 38, 30 and 25 mph.
• 80% efficiency, duct area ratio 1.4: 53, 42 and 35 mph.
• 80% efficiency, duct area ratio 2: 76, 60 and 50 mph.
• 90% efficiency, duct area ratio 1: 59, 46 and 38 mph.
• 90% efficiency, duct area ratio 1.4: 83, 64 and 53 mph.
• 90% efficiency, duct area ratio 2: 108, 92 and 76 mph.
Putting all this together:
• The figures in the paragraph above are worse case figures as they are steady state peak power using my intercooler and derived from practical experiments.
• Full power will be used only intermittently below 60 mph as my car will accelerate rapidly and/or traction may be limited, and even then the intercooler structure will act as a heat sink to be cooled after gear changes.
• Cruising and most road use will involve charge mass flow rates much lower than those for peak power, thus allowing higher duct ratios.
• Track use is the worst case scenario, involving as it does high power for longer. Looking at the figures above, track speeds will give 90% efficiency with a duct ratio of 2 ie an inlet area of ½ the intercooler area.
• The duct area ratio of 2 is higher than the duct ratio of 1.4 for the lowest drag losses but gives better cooling at expected car speeds.
Old age and experience will always beat youth and enthusiasm. Failing that, older people know more tricks and can afford better lawyers.
3 projects:
Designing systems for turbo-charged engine in Mazda RX8 and aerodynamic modding for mpg on road and performance on track
Mazda RX8 R3 for improved mpg (currently 17 mpUSg)
2001 Honda Accord 2.3 for improved mpg (currently 29 mpUSg in sedate driving)
