Old 10-28-2015, 04:31 PM   #21 (permalink)
darcane
darcane's Avatar
Originally Posted by Old Mechanic View Post
You need to replace the thermostat, preferrably with an OEM Honda unit. Make sure the system is properly bled when you refill the coolant. IF you dont when really cold weather arrives, you probably will not have any heat to warm the car. Gauge should read around half way within 1.5 miles.
Maybe, maybe not.
I don't know if it's true on all Civics, but on my '01 the factory gauge is all but useless. It has no numbers, just evenly spaced tick marks with one red one at the top. Based on what my Ultragauge reports, normal operating temperature (180°F) is only about 1/3rd of the way up the gauge, when the fan turns on (206°F) it's still less than halfway. When my headgasket blew and it was overheating (~230°F) it finally got to halfway. I have no idea how hot it would have to get to hit that red mark, but I bet the head would be warped.
So, good advice on the thermostat, just be aware that the gauge may give you poor information.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
The Following User Says Thank You to darcane For This Useful Post:
98civHX (10-28-2015)
