Old 10-29-2015, 09:08 PM   #358 (permalink)
BabyDiesel
Lean Burn Cruiser!
BabyDiesel's Avatar
Big Blazin' - '88 Chevrolet K5 Blazer Silverado
90 day: 14.97 mpg (US)
Chili - '00 Honda Insight
Gen-1 Insights
House of Tudor
Team Streamliner
90 day: 72.29 mpg (US)
You know you're an ecomodder when one of the first things you do after you move is evaluate your new route for fuel economy potential.
It was so second nature that I didn't realize it the YKYAE connection The route would have been a winner, but I got let go from my job yesterday. No biggie, I'll just go out and find another
Originally Posted by kafer65 View Post
My WAI is on the heat shield. I had my lower grill block off to see about building shutters and I couldn't get the WAI up to temp. Put the block back on 100% closed today and I maxed out at 150F after 10 miles. I think the headers area is the path out of the engine bay. I'm going to pull the front off like you're showing above and get the shutters done.
The reason I had 100psi set on my Beetles FI is to try to fatten up the boosted air/fuel ratio. I'm going to put it back down to about 55psi when I get it running and just be satified with 3 pound of boost.
Ah! I see why you went so high with the fuel pressure now. Lean + turbo usually is not good on pistons and blocks!
I'm topping out at 110F with my WAI per SG. It is actually higher, but I have 2 resistors on the IAT (1 on each wire) to advance timing, and that tricks the computer to seeing cooler IAT's than it really is. I would not doubt I am running 130-150F actual temps. I will be removing one, if not both, resistors to bring my part throttle timing back down. I have been spark knocking far too long, and this is while running 93!
On a different note, the gas station that I have been using for the past few months is getting changed from a Hess to a Speedway!
Gas - $8.88, Diesel - $9.99... I can see the future on their sign lol
I'm in need of gas, so it looks like I will be switching gas stations yet again. I will be going to the Wal-Mart that is a 1/4 mile down the road. 93 octane is the same price I might try 87 for a tank and see how that does running lean.
With regards to FE, here is what I am getting at he moment on my instant readout. These are close approximations, and they might seem to be patterned. I can assure this is how it is. I have never heard of a car dropping 1 mpg for every 1 mph over the best mpg speed!
40 mph - ~70 mpg
45 mph - ~65 mpg
50 mph - ~60 mpg
55 mph - ~55 mpg
60 mph - I assume ~50 mpg, but i never drive this fast!
Remember, thank a fellow EM'er for a helpful post!!!
I hypermile better in my cowboy boots
Past threads:
ZX2 modding thread
Ecomodder's Top 10: How they do it!
ZX2 Aerodynamics: Shooting for 0.15 Cd
ZX2 coast-down testing for Cd & Crr
The Following User Says Thank You to BabyDiesel For This Useful Post:
MobilOne (11-13-2015)
