Old 10-29-2015, 10:26 PM   #29 (permalink)
98civHX
Originally Posted by 97-civic-ex View Post
On thing that really affects mpgs on Honda lean burn is EGR system condition. Are you getting any check engine lights? Make sure the check engine might comes on for a few seconds at start up to verify the bulb is functional. The main issue with the EGR system is clogged passages and sticky/faulty EGR valve.
No check engine light at all. I figured that I would clean it out since I've read that it helps out with mpg. I just sea foamed the car and I've notice little improvements, especially with the idle. If someone thinks I shouldn't clean the egr passage ways please let me know.
