Old 11-01-2015, 09:53 AM   #71 (permalink)
IamIan
IamIan's Avatar
Originally Posted by The donkey CRX View Post
That's great Ecky. I think the 2000 Insights do go into lean burn easier and each model year and recall upgrade after that added parameters for lean burn to cut back on NOX.
Our LX's only require a water temp above 145 degrees for lean burn and of course no NOX purge cycles either.
If you haven't seen it yet .. And you are ok with the side effects .. you can disable the NOx purge cycles on the Gen1 Insight as well.
As Much Lean Burn as You Want
10-29-12 Post#73
Originally Posted by uhtrintiy
On the other hand if the secondary O2 sensor returns a value < .3v, either pulsed or continuous a P137 code (voltage low) will be pending and will set at about 10 miles. However the purge cycles disable and lean burn will run continuous as long as engine load is under the normal expected range. Under the P137 code all other functions including autostop work as intended.
Post #98
I want to reiterate, this 'mod' isn't a miracle fix that gives lean burn all the time. It seems that it puts the system into an error state in which lean burn still functions, but disables the ability for the system to enter into purges. You still have to have conditions that normally allow lean burn.
Life Long Energy Efficiency Enthusiast
2000 Honda Insight - LiFePO4 PHEV - Solar
2020 Inmotion V11 PEV ~30miles/kwh
The Following 5 Users Say Thank You to IamIan For This Useful Post:
aerohead (04-16-2016), brucepick (03-04-2016), Ecky (11-01-2015), TDFbound (11-20-2018), UltArc (04-13-2016)
