Thread: Cd 0.38
Old 11-01-2015, 10:41 PM   #13 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by skyking View Post
My TDI's fuel specifics are so much better than a gasser, and I will be adding a 6th gear eventually. I don't imagine that being an issue, ever, at any speed.
I believe our diesels are less sensitive to throttle position changes due to the diesel engine's lack of a throttle plate. Improved aero should only help efficiency since they simply add less fuel with reduced load and can run very lean compared to a gasser. That said, if you can do the 6 speed swap and keep the engine at about 1,800 rpm at your chosen highway speed that is the sweet spot for BSFC for the TDI. It's on my wish list.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
