I have an idea for pulse and glide: since your engine is in glide mode longer than pulse, why cant you change something to make more power during the pulse mode. ideas would be hydrogen you generate and store up to burn during the pulse, to give you extra horse power. (less fuel used during the pulse) and the extra heat created hopefully would dissipate during the glide. Or modify the air fuel ratio during the pulse, a leaner burn which would not be good continuously but if only used for the pulse may be ok. Think of something that would give you a boost during the pulse that may not be advisable continuously. we know other fuel blends can make more power in a diesel but will over heat the engine, but maybe not in a pulse mode. or what about a electric turbo that turns on during the pulse? HHO would be easy to make with the wind drag already slowing down the vehicle, put the wind drag to use. its hitting the front of your car anyway. a permanent magnet alternator should to the trick with a large fan blade attached to it. (see forever car on you tube) let the HHO build up in a pressure container and use it during the pulse. Any ideas?
