Originally Posted by superrick
<Snip> look I am not a person who just started investigating free energy. I have a lot of knowledge and skills and I also have in our group a beginning QEG generator that we have not been able to get it to resonate yet but we still get two times more energy out than we put in.
If that is true put it in a feed back loop and extort money from the world by threatening to destroy it. You'll get about as many people to send you money as you will find people here to believe that kind of claim.
also I have successfully harvested gravity to do work. in the case of gravity I do have to put energy into the system as it takes energy to move mass, and then the mass has to oscillate so gravity can keep acting on it. allowing gravity to continually enter the system. its a mechanical amplifier. and you can use the amplification to do more work than your original input. so you can argue its not free because I had to build the device to harvest the excess energy but to me I see the excess as free.
A mass and a spring and gravity make an oscillator not a amplifier. Once again my comment about threatening to destroy the world with it applies.
as for HHO taking more energy to create than you get out of it when you burn it that is correct if you have to use high amps to separate the atoms. but we know that separation can be done with strong magnetic fields using high voltages, which use very little current. making it so you get more energy out than you have to put in.
Here is the part that got me to really call out your BS. Hydrogen and Oxygen separation through electrolysis of water are directly related to the current flowing through the cell. Its the electrons passing through the molecule of water that separate it . Voltage across the cell is irrelevant to gas production so long as it is high enough to start the process. Magnetic fields don't even come into play.
How do I know? I have had to design charging systems for lead acid batteries and when you over charge or quick charge the hydrogen production is a problem.
If you heat a room by collecting the suns rays through a window have you not collected and used energy for free? there are many ways to collect free energy, as in you don't have to pay for it after you create the environment to collect it.
and adding a fan to the front of my vehicle yes will create more air resistance but what if the generated power does more for my cause than the air resistance takes away?
thanks for you input but you are all over the map here. and there is only one relevant response here. You are lacking in knowledge, information that when reckoned with in the mind and proven to be true becomes knowledge and therefore truth.
Okay calling us all over the map is ridiculous. We all say its a bad idea.
