Originally Posted by Trinost
Baltothewolf I looked at your link:
Q1
What type of AWG is the black wire that you use for the kill switch feeding through the fender? (Cannot see it on the spool)
Q2
How do I know which side is hot?
Q3
What exactly is a jumper?
-- Correct me if wrong, It looks like a jumper is the hot wire (guessing hot from red insulation crimp) tied with another wire allowing the hot to go to two different pins?--
Thanks
I just used what I had handy. Someday I'll go back and downsize my AWG wire.
How do you know what side is hot? the wire that goes into the cabin is a ground to the relay to ground the relay out, so it will cut the power to the injectors.
The power I used to the relay was the same power coming from the injectors.
