In terms of preserving safety, I wouldn't replace any factory corner lighting with LED (tail markers brake, signals etc). As trendy or power-saving or color changing as LED might be, they simply are not tested and approved by the manufacturer. Add weather into the mix and the problem can be compounded. I want to have max visibility to the cars around me as intended by the manufacturer. There will be a few that are improved by LED drop-ins but you can't universally put an LED bulb equivalent in a housing and expect it to perform as well as an incandescent.
Interior..no issues mod away.
2013 Honda Civic Si - 2.4L
OEM front to back belly pan from the factory.
