Old 11-09-2015, 11:19 AM   #11 (permalink)
XJ Cherokee - '00 Jeep Cherokee Sport
90 day: 12.96 mpg (US)
FoFO - '11 Ford Focus SE
90 day: 36.78 mpg (US)
I'm thinking about getting a set of their Headlights for the Focus. H13 bulb. Just need to see if it will fit.
And their tail lights and reverse lights ...
Old 11-09-2015, 08:54 PM   #12 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
PaleMelanesian beat me to it: SuperBrightLEDs is really good about posting luminous efficacy on their listings. And of course they're also pretty good about selling specific colors, so you don't wind up losing any of your generated brightness in the lens. You buy 100 lumens of orange, most of it goes through your marker light lens instead of getting wasted in the filtration process.
Old 11-10-2015, 12:29 PM   #13 (permalink)
Got MPG?
The Car - '09 Toyota Corolla CE Enhanced
In terms of preserving safety, I wouldn't replace any factory corner lighting with LED (tail markers brake, signals etc). As trendy or power-saving or color changing as LED might be, they simply are not tested and approved by the manufacturer. Add weather into the mix and the problem can be compounded. I want to have max visibility to the cars around me as intended by the manufacturer. There will be a few that are improved by LED drop-ins but you can't universally put an LED bulb equivalent in a housing and expect it to perform as well as an incandescent.
Interior..no issues mod away.
2013 Honda Civic Si - 2.4L
OEM front to back belly pan from the factory.
Old 11-10-2015, 12:44 PM   #14 (permalink)
Now that's just plain silly: assuming a 1988 vintage (design, at least - who knows how many times they've been replaced?) bulb is going to be more reliable than an LED.
Besides, I'm really not interested in safety per se, but in not running the battery down if I happen to leave the parking lights on. Then too, for brake lights there's the extra 1/10 second or so reaction time with LEDs...
Old 11-11-2015, 09:00 AM   #15 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Directionality is only an issue with headlights. I haven't changed those.
The LED replacements I have are equally as bright or brighter than oem. I'm approaching three years and none have failed. (besides the cheap ebay ones but they were meant to be a test and proved to be sub-par as I expected)
Old 11-11-2015, 09:23 AM   #16 (permalink)
Master Novice
elhigh's Avatar
Knowing how poorly incandescents survive in as rough a service as automotive, I wouldn't hesitate to replace virtually every bulb with LED with the possible exception of headlights. The only thing holding me back is money and opportunity. I just got done replacing several lamps on my truck with LED and they're noticeably brighter.
Old 11-26-2015, 03:47 PM   #17 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Visual comparison of cheapo led's and "super bright led's". Cheapo one is on the right.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 12-22-2015, 06:59 AM   #18 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
[IMG][/IMG]
Hah, but you bought the cheapest ones on superbright, they do sell bulbs intended for dash panels and the like where you don't really want them to be that bright.
If you buy the best bulbs on superbright, they'll typically be slightly brighter than OEM. The only ones that really fail are white bulbs for DRL's, white is one of the least efficient LED colours, though my reverse lights are fine.
Old 12-22-2015, 01:42 PM   #19 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
These aren't really comparable. Superbright used to sell LEDs like the one on the left, but those are getting harder to find because they use chips with less output and are a directional board, whereas the "cheapo" on the right is what Superbright mainly sells now, and is designed for nearly 360-degree output.
There are many, many threads on LEDs for automotive use, LED design, LEDs in incandescent reflectors, etc. on HIDplanet. I went full-LED a while ago (the only incandescent bulbs left are the high beams), and, to get things just right, there will always be something to tinker with. I'm happy with all my interior lights and license plate lights, but will probably replace my turn signals and reverse lights at some point with a design like this that will fill the lens better and be brighter than the lower-lumen bulbs I have in there now.
Superbrightleds has good prices and good selection; V-leds cost more but are a generally more-reliable product with their own proprietary designs, and crazy expensive if you get their Triton line (which are length-adjustable, so they can be tuned to your particular housing). You can find a wide selection of LEDs on Amazon, but it's always a crapshoot depending on the vendor. Philips has a line of LEDs (in limited bulb sizes) designed for incandescent replacement available at Autozone, and Osram is coming out with their own line of automotive LED replacement bulbs soon. The Philips LEDs have something like a 10- or 12-year warranty, and I expect the Osrams will too.
Also, in terms of power-to-output ratio, red LEDs are least efficient, then amber, then white. To produce these colors, the LED (which is blue) has to be filtered. For an example, the bulbs I linked to are available in red (700 lumens/amp), amber (875 lumens/amp) and white (1363 lumens/amp).
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
NeilBlanchard (12-23-2015)
Old 12-22-2015, 09:25 PM   #20 (permalink)
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
i replaced a few LEDs in the house, 60w equivalents. the "best buy" cheapies, 2 have quit working. the GEs are still running strong.
I find that lumens and watts are not interchangeable. all companies have their own method for testing.
I have bought from Ebay, straight from the manufacturer and 3rd parties. you gat what you pay for but when you find a good supplier and the price is good, technology changes and you will have to start all over again. even most of the threads on HIDplanet are outdated. it gets confusing after a while.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
