Old 11-14-2015, 10:02 PM   #6 (permalink)
S Keith
Originally Posted by 3-Wheeler View Post
Sounds like your battery will need some trickle charging to help get it balanced again. In that case, the link will give you some valuable information.
Picasa Web Albums - Jim - Battery Trick...
Jim.
This is generally true; however, it depends on the source of the P1449. If it's P1449(74), it's likely that you have a shorted cell, and no amount of grid charging will produce useful results.
For a cheap and quick grid charger:
http://www.mouser.com/ProjectManager...sID=43eb56731e
Steve
The Following User Says Thank You to S Keith For This Useful Post:
1carnut (11-15-2015)
