Old 11-15-2015, 02:47 AM   #2 (permalink)
MobilOne
Will it work correctly in another car? If it won't, then bad Scangauge. If it will, then bad connections or OBD2 data in your car.
Other questions come to mind. Did you buy it new or used?
Is the OBD port output the same in your Swift as in a Swift sold in the USA?
