Thread: EPA may fine VW
Old 11-22-2015, 11:32 PM   #160 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
SCR is the device that uses that urea-based reagent, and IIRC it was absent from the majority of the vehicles fitted with the EA189 engine. The system that suffers regeneration is the DPF, the particulate filter.
Correct. Mercedes Benz developed the AdBlue urea treatment to reduce NOx in their diesels and BMW adopted it as well. VW came up with their own solution which doesn't involve urea injection but uses high pressure and low pressure EGR circuits to lower NOx and periodically dumps fuel into the exhaust to clean up the DPF filter. It is likely that engine longevity, power and mileage will be reduced to meet current Tier II EPA requirements. The crazy thing is that our '11 Audi TDI is much cleaner than the '04 TDI in my avatar and everyone is up in arms about the EA189 diesel engine. This will likely take years of litigation in the courts before we have a final answer in my humble opinion.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
