Old 11-28-2015, 05:13 PM   #15 (permalink)
jamesqf
Benefits vs how the Insight is set up now:
Allows electric-only driving
I wish you'd explain why you think this would be a benefit, when you have only a relatively small battery. You could only go a mile or two on electric, and doing so would add many charge/discharge cycles. Seems far better to simply use the IMA system as designed. (With of course the addition of MIMA.)
