Originally Posted by cyclopathic
2) the aerodynamics of C are worse than Toyota say. CD is definitely worse than .28
I would not say this, but that it is highly likely that the Cd is greater than 0.28. If you can perform coastdown testing per Instructables.com, then we could find out for sure and settle this
The C's Cd 0.28 would match the Mitsu Mirage, and they look similar IMO
![](http://t2.gstatic.com/images?q=tbn:ANd9GcQqNckEy-wxCuRPjxilT0HcwASp9zO1ayizas53X4ph71XmppJq)
