Old 11-29-2015, 10:17 PM   #32 (permalink)
S Keith
The tabs on your Honda pack are the PTC strips. Honda eliminated them part way through HCH1 production. Most Honda packs, whether they have the strips or not, have the wire cut. It's a deliberate cut approximately 1" long per a service bulletin.
To my knowledge, no aftermarket packs have those installed. If your Honda is cut, you are good. If not, you need to get an ECU update OR put in a resistor.
I'm kicking myself for not remembering this. I don't have to deal with it on my HCH2 or on my G1 insight with an aftermarket pack, and I forget it's an issue.
Again, if your wire on the Honda is not cut at the orange board, the fix is likely an ECU update or a 20 Ohm resistor in line with the cut blue/yellow wire.
Steve
The Following User Says Thank You to S Keith For This Useful Post:
rpearson (11-29-2015)
