Old 11-29-2015, 11:19 PM   #32 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
I found this thread late but what a cool swap! Can you post your mileage since the diesel/6 speed manual swap? Did it double in real world driving?
Originally Posted by dremd View Post
Also decided to go to higher temperature thermostat.
Modified Thermostat for higher MPG's... - TDIClub Forums there is a great white paper linked in there someplace BTW.
I got a Stant Super Stat because most people have them run in the 200-205 range despite being rated for 195. I'd do the hybrid, but that is a tad scary for me. Hopefully that's good for about 1-2MPG.
The factory thermostat does 188, but fades to 182 in about a year and a half, so this should be about 20f warmer than my last car was running.
Yes, I now have a larger oil heat exchanger and have always run high grade synthetic lubricants. And, Yes, I want an active grill block pretty bad.
I have been running the Stant Super Stat for about 2 years and once warmed up it stays at about 207º F on the ScanGuage II. I seem to have picked up about 4 mpg. I did a Malone intelligent EGR stage I tune at the same time so it is hard to say how much is because of the thermostat.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
