Originally Posted by S Keith
The tabs on your Honda pack are the PTC strips. Honda eliminated them part way through HCH1 production. Most Honda packs, whether they have the strips or not, have the wire cut. It's a deliberate cut approximately 1" long per a service bulletin.
To my knowledge, no aftermarket packs have those installed. If your Honda is cut, you are good. If not, you need to get an ECU update OR put in a resistor.
I'm kicking myself for not remembering this. I don't have to deal with it on my HCH2 or on my G1 insight with an aftermarket pack, and I forget it's an issue.
Again, if your wire on the Honda is not cut at the orange board, the fix is likely an ECU update or a 20 Ohm resistor in line with the cut blue/yellow wire.
Steve
No need to kick yourself. Our previous problems were because we had a disconnected plug. I believe the new error code with the refurbished battery is P1600 but I'll need to check. With the plug connected the car ran with the old battery and no error codes. The old battery was charging, but way too fast. It went from 0 to 4 or 5 bars in a quarter mile of driving. I will confirm the error code on the refurbed battery once it I have put it back together properly and reinstalled it. Before I do that I want to convince myself it is wired properly.
