Old 11-30-2015, 04:02 PM   #38 (permalink)
S Keith
Here's a direct link:
https://dl.dropboxusercontent.com/u/...1/P1010247.jpg
Try that.
The Honda pack will be cut inside the junction board, not outside.
If your Honda isn't cut, you need the ECU update or splice in a 20 Ohm resistor between the red and blue/yellow wires.
The previous owner's car must have had the ECU update. If the ECU doesn't expect a signal on that line, it trips a code. If it expects a signal on that line, and it doesn't get one, it trips a code.
Another thread about this:
http://ecomodder.com/forum/showthrea...new-31958.html
Here's the link to the TSB about junction board replacement:
http://honda-tech.com/attachments/in...el-a12-048.pdf
It doesn't discuss the specifics, but indicates that it is not to be repaired.
The Following User Says Thank You to S Keith For This Useful Post:
rpearson (12-03-2015)
