Old 11-30-2015, 03:11 PM   #39 (permalink)
S Keith
Originally Posted by rpearson View Post
Oh also, the original owner of this Greentec battery told me after he cut the wires, and it didn't resolve the problem, he respliced them. But we're pretty sure he respliced them incorrectly, as the blue/yellow stripe is now spliced to a red. He did this four months after the new battery was in (when it started having problems, he called Greentec).
PS I think I fixed the pics let me know if they are still broken. (I can see them).
I can see them. I'll check my HCH1 harness when I get home and let you know.
So, it looks like 2 things are needed to get that pack working... potentially fix the splice job and install a 20 Ohm resistor.
BTW, this harness is for monitoring the 3 thermistors and the PTC strips. Simplistically stated, the PTC strips are basically a resistor that runs along the length of each stick with with a probe on each cell. If even a single cell gets dangerously warm, the strip resistance goes very high. The 20 PTC strips are connected in series between the red and blue/yellow leads. A 20 Ohm signal tells the BCM that there is no catastrophic cell heating going on. With that signal steady, the BCM operates normally based on the 3 thermistors.
No aftermarket packs contain PTC strips. Honda discontinued them on the HCH1 sometime in 04. They haven't been on an HCH2, G2 Insight, CR-Z or Accord Hybrid. However, you may the ECU that expects them.
Steve
The Following User Says Thank You to S Keith For This Useful Post:
rpearson (12-03-2015)
