If we have them do an ECU update, do I ask them to flash it? I want to make sure to use the correct term when talking to them.
Although I think we can install a resistor. That would give us more flexibility if we refurbish the old battery, as they will both use the same ECU software (both have "PTC" -- although one is just pretending with the resistor). am I correct?
and thank you, your advice has been amazing!
