Originally Posted by BamZipPow
Belly pan view from the backside...
Thinking about installing a 2" receiver below the reflective bar and use that as my jack point. I would have to bolt a 2" tube to the trailer jack which would allow me to insert it into the receiver and pin it in place. No more bolting or unbolting. I would have to make sure to crank the trailer over so the wheel pant would not be in the way.
3500 Lb. Capacity Step Bumper Receiver
Looks like I could also install the rear lights and license plate under the reflective bar which would then allow me to plan taper the back end down. I would install a flip up bracket fer the license plate which would hide the receiver hitch.
I would have to beef up the extended section that I have on there now with some better steel brackets and better horizontal plate fer the receiver hitch to be attached to.
