The first error code was 1420. I do not believe the ECU has been updated. I will make an appointment to have that done tomorrow!
Master switch has been on, the electric start still works. Per recommendation, I left a voicemail with Bumblebee. Sadly, they close at 5pm.
Thanks for the information about the 12v! I will get it load tested this weekend and will also get the ECU update. I will reply asap with (hopefully good) news!
