With a clearance of 8" from the rear axle to the ground, I can roughly calculate the exit angle of the rear diffuser to the back end of Dark Aero.
Right Triangle Angle And Side Calculator
15" - 8" = 7" (Side a)
11'2" = 134" (Side b)
Angle A =2.99 degrees
So the exit angle is 2.99 degrees.
