Old 12-12-2015, 12:48 PM   #49 (permalink)
aerohead
carb heat
That is kind of what I was thinking and that is what word of mouth has always been on them.
Tiny single bore, no accelerator pump.
I am just trying to put a 4bbl edelbrock on top of a coolant warmed carb heater plate.
In the 1960s,GM had thermostatically-controlled exhaust heat diverters built into their intake manifolds.
My CRX also had carb heat via hot coolant circulation and also t-stat controlled hot air riser into the air cleaner housing.
