Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 10-13-2015, 05:38 PM   #41 (permalink)
Originally Posted by RustyLugNut View Post
All because I bought plans from the back of Popular Mechanics for the Pogue 200 mpg carb and other wacky devices.
I just saved up for X-ray specs from the back of Boys' Life. Man, was I disappointed! I could not see inside my Christmas presents!
Old 10-14-2015, 01:50 PM   #42 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
There's more opportunity for higher fe in the hills, especially with a stick.
Can be. I struggle with hills, high-octane commuters climbing up my tailpipe and a failed IMA pack. But I do okay.
Old 10-14-2015, 06:49 PM   #43 (permalink)
P&G on the flats stinks. On the hills, much better.
aerohead (10-17-2015)
Old 11-12-2015, 08:32 PM   #44 (permalink)
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
I rock the hills, a few years back I was working in Seneca SC with a 25 mile commute including a bunch of hills, I consistently got over 40 mpg for 5 tanks averaging 55 mph or so with about 1/3 the distance rolling motor up coast down hills. My LT Average is 34.8 and never better than 36 mpg in flat ol Florida. Vroom.
Old 12-08-2015, 06:24 PM   #45 (permalink)
Fuel Vapor Carbs
Here is a book I got though Lindsey Publications,advertised in the back of Popular Science or Mechanix Illustrated.
It has the patent illustrations for about a dozen fuel vapor carbs,and testimonies and anecdotal evaluations.It was about $12 (US).
Old 12-08-2015, 07:25 PM   #46 (permalink)
I am trying to build one, a real one.
http://ecomodder.com/forum/showthrea...tor-32977.html
Just need to put it together.
Got any pointers?
I only expect mine to help fuel economy in cold conditions.
Old 12-09-2015, 06:04 PM   #47 (permalink)
pointers
Got any pointers?
Get a push car and driver.Each time you drive,you'll need a push up to 35-mph so you can start the car and drive at 35-mph.
When your forced to stop at a sign or traffic light,keep that push car close by,as you'll need it each time you start off.
Don't expect to drive any speed other than 35-mph.That's all these carburetors will allow for.Seriously!
Old 12-09-2015, 07:43 PM   #48 (permalink)
That is kind of what I was thinking and that is what word of mouth has always been on them.
Tiny single bore, no accelerator pump.
I am just trying to put a 4bbl edelbrock on top of a coolant warmed carb heater plate.
Old 12-12-2015, 12:48 PM   #49 (permalink)
carb heat
In the 1960s,GM had thermostatically-controlled exhaust heat diverters built into their intake manifolds.
My CRX also had carb heat via hot coolant circulation and also t-stat controlled hot air riser into the air cleaner housing.
