Old 12-13-2015, 06:14 PM   #2470 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
Also, if you type "save" it will save the settings I hope. I haven't checked that it properly saves and loads everything with all the new settings available. So, hopefully you only have to set up the throttle once and then never again. Just remember:
Code:
0 < fault-throttle-position < max-regen-position < min-regen-position < min-throttle-position < max-throttle-position < 1024
If you type:
stream-raw-throttle 1
data-stream-period 1000
Then, you can do all the adjusting and it will show you on the fly what the raw throttle is. Then, you can choose what positions you want for fault, max regen, min regen, min throttle, and max throttle.
To stop the data stream, just hit enter.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
thingstodo (12-13-2015)
