Old 12-15-2015, 12:43 AM   #61 (permalink)
planejob
BeginnerModder
Originally Posted by kimer6 View Post
Let the fun begin!
Oh yeah!
If the adapter plate is .500'' thick the throwout bearing and the clutch disk will sit in the same place as the stock setup. However.....
Exactly! I measured the "magic number" back at the start and came up with some .470 aluminum plate.
As for the pilot shaft. I considered this: Drill out the crank using the current pilot bearing as a guide. Get it nice and centered using the pilot bearing, and then, pull the old bearing out, enlarge the hole slightly, replace the pilot bearing with a new one, and then get the tranny colinear using the new bearing as a guide (along with the dial indicators). Nothing is settled yet.
