Old 12-15-2015, 05:35 PM   #63 (permalink)
planejob
BeginnerModder
Here's the difference between the bolts. The 5 are the flywheel bolts, and the 1 odd one is a flexplate bolt for comparison.
A freshly washed transmission:
It started like this:
The plan for tonight is to drill a new hole for the dipstick, remove the oil pan, and set the engine on the mating cradle.
Kimer, how did you move your oil filter? Mine looks like it should just swap to the other side where the block off plate is, but... the block off plate does not key into the oil filter mount...
