Thread: 97 Civic HX
Old 12-19-2015, 06:57 PM   #6 (permalink)
conor97hx
rice rocket - '97 Honda Civic HX
90 day: 32.61 mpg (US)
A friend of mine had 2 spare rear upper control arms with good bushings and they weren't bent, so the last pieces of the suspension are in and i got them for free all the suspension needs now to get the alignment in perfect spec is a new toe adjuster bolt.
From there my plans are -
Suspension -
Toe adjuster bolt
Inner tie rods
Power steering lines/pump
Re align
Interior-
Visors/headliner
Horn/srs steering wheel trim
Miscellaneous trim pieces
Clean/dye interior to black
New dimmer switch/figure out what's wrong with gauge cluster
Fix windshield wipers
Motor-
Fix fans
Oil/trans/coolant/brake flushes
Replace leaking brake booster
Valve adjustment
Windshield wiper tank
Finish wire tuck
Re paint valve cover
Bleed clutch/brakes
Get registration/inspection
