Old 08-02-2008, 11:04 AM   #41 (permalink)
gascort
gascort's Avatar
Gascort RIP - '93 Ford Escort Wagon
90 day: 43.01 mpg (US)
WifesCruze - '11 Chevrolet Cruze LT
90 day: 31.1 mpg (US)
I'm planning on getting a ~50W panel to mount into the roof of my wagon. I'm going to put the alternator in circuit with a small lawn mower battery, the computer, ignition, fuel pump, engine cooling fan, and injectors.
I'm going to keep the solar PV panel connected to a deep cycle battery and then to all the non-integral parts of the car (starter, headlamps, parking lights, stereo, blower motor....) and have a switch between the two systems that I can connect for long road trips. This way, I can always get the car to go, even if the deep cycle battery or PV system fails somehow. From the previous post, I don't think the essentials will bog down the alternator too badly, and I'll be able to maintain use of the alternator's slightly higher voltage for my ECU and injectors, which I believe to be important for economy.
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
