Old 12-23-2015, 11:08 AM   #142 (permalink)
TimV
SUVcruiser - '07 Ssangyong Kyron 2.0 XDI
90 day: 42.55 mpg (US)
SUVcruiser year 2017 - '07 Ssangyong Kyron 2.0XDI
Hybridcruiser 2023 - '13 Volvo V60 D6 AWD
90 day: 123.84 mpg (US)
Originally Posted by oldtamiyaphile View Post
You can use a solid state flasher relay to fix this.
Yes, that is an easy fix. But realy, how mucht time is a blinker on? So how much amps are you saving? I aim not going for an alternator delete, only for lower draws, so the electric heaters can work better.
Are you sure you really can't change all the lights for LEDs?
For the low beams I aim pretty shure that I wont pass the anual car inspection with those being leds...
I tested yesterday how bright the front fog lights are. Those are 27W light bulbs. The low beams are 55W light bulbs. So if i can change the fog lights to high power led lights (so it outputs like a 55W one) then it is ok. The light patern is a bit whider but almost the same distance. If i did the convertion then i would run the parking lights and the fog lights to save amp draw from the alternator.
Drive smart, save fuel, save money, spare the enviroment
But keep having fun!
I can drift
Previous car. SUV. From 2011+ 10l/100km to 2017 5,516l/100km.
2017 without holiday: 5,397l/100km
EPA Rated average: 8,1l/100km
Current ride: plug in 285hp hybrid
EPA Rated average: 2,8l/100km
