@Old Mechanic
I hate to say it but I think I probably messed up the rims and your post basically confirms it.
I only put soap on half of the rim (you can get in half the tire first and then you need to lever the other half on and the soap helps a lot) because I heard that the soap is a mild-solvent and is not the greatest thing in the world for the tire. I to tried to get all the soap off the rim and tire before I set the bead, so basically the bead set dry but I'm sure one half of the tire had more of an inclination to slide further.
I wonder if someone else could confirm if how the bead sets makes a difference or does the bead always expand out equally once the tire is fully inflated.
Do the pros use tire lubricant when they set the bead?
Reason: The reason why I only put soap on half the tire
