Next time you do tires yourself, remember to get the tire on with the least force you need to get the tire's bead down in the recess in the center of the rim, especially on the last side you install. A couple of C clamps makes it much easier. Another way is to use plastic wire ties to keep both of the tires beads very close together then cut them off or remove them (the plastic wire ties) when you have the tire completely installed.
https://search.yahoo.com/yhs/search?...&hsimp=yhs-003
regards
mech
