Old 08-02-2008, 01:49 PM   #42 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Gascourt,
Are you sure you can isolate all those functions? My personal preference is to keep it simple. You never know what is connected to what in wiring harness. Unless you happen to be an electrical engineer then fill your boots.
The frictional losses in the belt would surely outweigh the slightly cooler spark and the fuel pump is designed to maintain a certain pressure regardless of voltage ( as long as it's not too low)
But I'm a bit of an idealist. I'm removing all the parasitic drag off my previa. Bye Bye belts!
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
