Old 08-02-2008, 02:07 PM   #44 (permalink)
gascort
gascort's Avatar
Gascort RIP - '93 Ford Escort Wagon
90 day: 43.01 mpg (US)
WifesCruze - '11 Chevrolet Cruze LT
90 day: 31.1 mpg (US)
Originally Posted by orange4boy View Post
Gascourt,
Are you sure you can isolate all those functions? My personal preference is to keep it simple. You never know what is connected to what in wiring harness. Unless you happen to be an electrical engineer then fill your boots.
I should be able to isolate everything at the fuse panels, using some male and female connectors. I believe I only need to do this to 5 fuses. Shouldn't take more than an hour.
The frictional losses in the belt would surely outweigh the slightly cooler spark and the fuel pump is designed to maintain a certain pressure regardless of voltage ( as long as it's not too low)
You are correct, these should be fine. The speed of everything in the computer is driven by the voltage that serves it, though, and since I've seen sensors, etc. get thrown off by voltage problems before, I don't want to mess with it if I can avoid it easily.
PLUS I need the car for occasional trips to see my family in Kansas City, which is some 250 miles each way. This way, I don't have to worry about stopping to charge up or put the belt on, etc. with the wife and baby in the car. I already commend my wife for riding around with me in the car.
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
